delexploder's "Vader" 97 v8 sport | Page 11 | Ford Explorer Forums
Have you tried smashing the gas pedal down on the street? Does it pull with all four? Any wheel spin?
How long have you had the electric transfer case in?
I have and do smoke the 31s often, as a matter of fact i have to be careful taking off from a stop, also i forgot to mention i kept the brown wire mod from before the V8 swap, its mounted in the cosole next to a small amp
Oh ive had the e-shift case in for months now , just got back elite status this week lol
I'd say ive got at least a couple thousand hard miles on it
Well, welcome back! Good to hear from you.
Congratulations on getting that transfercase in too!
Yes, once its up there its not that bad, i believe ahodges is running this settup in his four door, the shift motor is three inches thick , most of it is kinda above the tank , and other than that its all the same as the manual 4406
right. i keep forgetting andy did that (and i have seen he's truck twice lol). ive never really crawled under his truck neither, i have only seen a few cell phone pics of it when i have talked to him
getting ready to start working on vader again,
And this
Spiders and clutches should be here tomorrow, gonna swap out the e-shift 4406 for a manual one and i have a fresh 30,000 mile front diff and all the manual hub stuff and the V8 torsion bars , good times ahead
Very cool, I missed your thread from years ago and didn't post/subscribe in it. I hope you're enjoying that truck as you get closer to what you wanted.
Its slow progress and my paint and body are rough at this point but i plan to keep going with it , i hope to do rocker panels and paint next year, and maybe some cubes and forced induction later this year
im sure you know this but they do sell rockers for 2 doors. cubes and forced induction eh? there are days when i just wished i never went as far as i did......that is until i wack the loud peddle....
I'm looking at going a slightly different route for the cubes , but will be trying to copy your setup with an M112 , i had heard LMC had 2door rockers now , im not looking forward to that job at all
got a little work done on vader last night , replaced my weeping radiator , the original one with almost 300,000 mi, swapped the plastic fan out for the metal one , changed the oil , cleaned the tb and maf , i hope to have the front dif swapped with all the new halfshafts and Whatnots for the manual hubs , and im working on getting the manual 4406 ready to swap out with the e-shift 4406 i have in there now , once thats all done its time to go to my friends shop to do the rear and the four door leafs
Just got done welding two t-case skid plates together like turtle did to make it strong enough to act as a mount to help support the 4406 , im using spacers to step it down from the frame and a large rubber freeze plug ,the kind with the stud sticking out , ill use that with a nut to bolt it to the skid plate so the rubber acts as a reasting point for the case
I hope that works, but I think it's way past time to get Brian to make us some special trans cross members for the 4R70W's.
Definitely hate the factory trans mount. As soon as you install an even low stage shift kit, they go to crap quick. EXPECIALLY aftermarket factory mounts. I had good success doing a bushing style mount on my old mountaineer. I need to make one on my ranger. Since my Torson bars are gone I can get a little more creative in chopping the factory mount out
I saw a trans mount laying on the ground at the JY a few months ago. That gave me the idea to send one to Brian, but I didn't have time that day to grab it and buy it. The mount isn't a simple straight across unit, it angles slightly forward/rearward from each side of the truck. That's why I think it'd be best to give him one to work with. Then he would just need to know how high to create the pad for an aftermarket trans mount. I hope to be working on the BW4406 this Summer, one of my first to do items.
got the swap done today ,
Not quite sure what i did to the e-shift 4406 but its toast, i wanted to swap in the manual one almost immediately after i put the e-shift in
