- November 6, 2000
- 2018 EX Sport Concept
It seems that later '01 Fords had body mounts that were of substandard quality, that literally fall apart after the material breaks down;
http://www.agcoauto.com/content/news/p2_articleid/183
Replacing these with the same parts from the dealer doesn't seem to make much sense, as the same thing will probably happen all over again.
Daystar makes a polyurethane body mount bushing kit, part #KF04009BK, for the 91-98 Explorers, that also fits the 99-01 Sports. It's around $150 online, but 4WheelParts has it on sale for $130. The kit may or may not fit the Sport Trac, but my guess is it will, or at least some of the bushings would, since I would think the cab mounts of the Sport Trac use the same 6 body mounts as the front of the Sport. They also make kits for other Fords, including newer full sizes, so it might be possible to find another kit that would have all the correct bushings, either by comparison to their stock rubber mounts or otherwise, if the kit doesn't have everything for a Sport Trac.
It's probably also possible to use the 91-98 Explorer kit and compensate for any differences between the heights of the bushings with steel washers, which might still be a better and less expensive alternative to the bushings from the dealer if they are $98 a pair and made of the same material that is just going to fall apart again.
On the plus side, since the rubber of the body mounts has fallen apart, the steel inner hardware is now accessable and super easy to remove, which is a good thing since you can re-use it with the new Daystar mounts.
