Gormy
- December 12, 2011
- Arena, WI
- 1998 Ford Explorer
I have a 2003 Explorer Limited, 4.6L AWD 3.73 LS rear.
As many others have experienced I also have noise from the rear. Although mine isn't quite the same as what others have posted in these forums. I do not have a whine noise that comes on around 35mph and disappears at 60. Mine sounds like a lot like a wheel bearing. It starts the low rumbling starting at very slow speeds and persists all the way up to highway speeds (I drive about 80mph at most and it's still there). It gets louder with speed and it does not go away when I let off the gas. It's matched to the speed of the vehicle. At cruising speeds it sounds like very chopped tires and excessive road noise.
Now before you go and say that it's obviously a wheel bearing - both rear bearings are tight as can be. There is zero play in the wheels in any direction when on the stands. I worked in automotive for 10 so I know most of the quick and simple tests. I just finished replacing both from wheel hubs, all four ball joints (upper control arms as well with upper ball joints), sway bar links, rear toe arms, rear brake pads and rotors and one brake caliper. I did all that on the garage floor. I had Ford install a rebuilt trans because the old one was experiencing all the early signs of failure. I asked them to diagnose the rear noise but they told me "they won't know if it's the differential making the noise until I replace both bearings to see if that makes it go away." Sorry, $660 on a whim is not a viable option.
So my question: With the symptoms I listed earlier does anyone know if this could still be a bearing that is not showing itself when tested, or one of the several internal differential issues?
Thanks!!
Thanks!!
