- January 26, 2004
- Mechanicsville, Virginia
- 2004 Acura TL
If you are expierencing a rough idle and you have a feeling it is the IAC Valve - Use a hammer and LIGHTLY tap the motor to see if there is a change in idle or the vehicle starts to idle correctly. Some IAC Valves will give a hiss/noise at idle. If you unplug the IAC and the noise goes away - this is your issue. Also, if you unplug the IAC and the idle is a little high, but better - then your IAC is probably bad.
This is a IAC Valve and it's location on a 4.0L SOHC Ford Explorer
-Drew
Visit here to read Karl Burns write up on IAC Cleaning
-Drew
