- August 1, 2008
- MO MO
- 94 & 95 XLT's
This should help you out. Only thing diff I do is put the rtv on the diff, instead of the cover, and I go all the way around the bolt holes. You dont have to use the ABS sensor to fill it, use the fill hole on the front side of the diff.
http://www.explorerforum.com/forums/showthread.php?t=242694
^^^That is all you need to know for the most part.
