ptf18
- June 5, 2012
- 2002 Sport Trac
Fellows Plan on changing the differential fluid in the wife's S/T. Its never been changed. 230k on the meter.
I have no idea what rear end is in it as the code on the driver door tag has long ago disappeared. There's a metal tag on the differential cover bolt but the numbers and letters on the tag do not match anything I find on the internet to inform me what they mean.
You all have given me some tips on attempting to ID the rear end but to no avail.
Anyways... I have changed fluid/oil in differentials before but would like to know of any "tips" you may offer in changing the fluid/oil in this S/T rear end. Quantity? Weight... I think its 75w140? Friction modifier? What does the cover use for a gasket? I assume some type of "liquid" rubber and not a paper gasket. I have have poor luck with that "liquid" rubber gasket stuff. If that is what is used any tips on how to use it properly?
than ks,
ptf18
than ks,
ptf18
