fire4effects
- May 20, 2009
- Columbia, SC
- 97 Eddie Bauer
I'm working on my daughters 97 Eddie Bauer 2WD 6 cyl. with tow pkg. Loud whine in the rear that dissapears when load is removed.
I have replaced universal joints and will be replacing wheel brgs/seals including new axles. RR axle was heavly fretted. While the rear end is apart I am considering replacing the pinion bearings and seal. I have done my research on the process including bearing preload via the crush sleeve. My question is how do you keep the pinion from turning when your are removing the pinion nut (disassembly) or crushing the sleeve (reassembly) BTW this is an awesome site!
