Skohler
- October 22, 2001
- Noblesville, IN
- 93 XLT 4x4
Thanks Jon,
That was what I was wondering. I did remove the small bolt that held the center shaft (that went through the center of the spider? gears. I did this to remove the clutch 'S' spring. Is that the bolt you were referring to with the locktite? Did you remove the large round ring gear from the carrier before trying to remove it?
I tried tapping all around with a rubber mallet just to try and break the bearing caps loose, it seemed to wiggle a bit but i didn't know if the pinion gear was holding on to the ring gear and that is why it won't come loose.
So you are saying place a pry bar behind the carrier and just try and pry it loose (without dinging up the gasket surface)?
Thanks!
Steve
Thanks!
Steve
