Arco, THAT LOOKS AWESOME!!!! Is the brain board in there too? Can you post a pic of the Explorer's cluster housing, so I can see where you cut it out? How are you planning to mount the display circuit board? I like the idea of keeping the shift indicator, and indicator lights in the stock location. I think I'll try going in that direction, I didn't think there was enough room for them. A cluster housing at the U-Pull I go to is only $5 (no gauges, just the white part).
I made a bit of progress myself today. I figured out how to mount the brain board, on the inside of the cluster, I got the front and rear of the display sandwich cut and fitted. I was originally going to use a third piece of plexi type stuff for the middle of the sandwich, but the displays wouldn't sit in place firmly, so I've decided to use gasket type material, that will compress and give a snug fit. Currently I'm using cardboard for this. Like I said earlier, I'm going to move my displays up a bit (like arco's). All that will affect is the gasket for the display sandwich. I'm going to paint the backside of the very front piece of the sandwich, and probably put a very light tint on the front side, just to even out any imperfections. For the backlight, I am going to order 2-13" lcd display ccfl's off of ebay ($25ish to my door). I also need to fasten the cougar's display circuit board to something, so it won't be just flopping around. I have some pics, and will post them in a few days once I get a completely fastened together housing.
NICE59, How's yours coming along?
