CS223
- January 12, 2011
- Florida
- 2005 XLT 4x4 FlexFuel 4.0
I believe I've got the dreaded rear differential noise. RH side seal is leaking, 73K miles 2005 4x4. Noise sounds like mud tires on the highway, I can feel the vibration in the floor board, it's been getting consistently louder and doesn't matter if it's loaded or coasting. Hub bearings feel smooth & quiet rotating the wheels by hand. I was wanting to put it up on jack stands and run it just to confirm 100% that it's not a driveshaft or hub bearings. Obviously, you can't do that with the Advtrac. I tried the master disable by holding the switch down but no dice. Is there any way to do what I propose or is there a better way to confirm the diagnosis? Axle lube looked good and level was OK when I checked it about 500 miles ago. Leak has gotten worse since then as has the noise.
