Disconnecting Sub | Ford Explorer Forums
Disconnecting Sub
Badali05
Highlands Ranch, Colorado
91 Eddie Bauer
What would be the easiest way to disconnect the stock sub? I need to disconnect it, b/c it is making an extremely annoying sound even wit th sub off on the deck it still seems to work. So any ideas would be great
Thanks, Derek
You can take the screen out by pressing on the edges, then unscrew the sub, pull it out and disconnect the connections. That's what I'd do. 5 min. job.
be sure to tape up the connectors when youre done. no use blowing an otherwise good amp
The only screws to get out are the 3 on the front of the sub right?
