Do I have an Amp in the rear? 2000 Explorer XLT | Ford Explorer Forums
mikec557
Oregon City, OR
2000 XLT
I have read so much that I am slightly confused. Additionally, I had a new radio installed and was charged for something I think may not have been done, or not needed.
I have a 2000 Explorer XLT with am/fm/cd, no changer. The back of the center console has some radio control features. As far as I know I have only 4 speakers, two in front and two in second row passenger area. I do not have a separate sub woofer, at least I have never heard one operate in the 9-years I've owned this vehicle. In the right rear corner of my cargo area I have a recessed "stuff your junk here" pocket.
I was told by the stereo install place that "almost all Explorers" have an amp that needs to be bypassed and that it would cost $35 for a cord and about $35 labor. I told them if I have one, then do the bypass. When I picked the Explorer up I was told that the installer knew a trick way to not have to do the bypass "at the amp in back location" and that his method did not need a cord and my labor had a small up charge but the upcharge was less than the $70 p&l for the normal bypass. But the upcharge was $60, a $10 savings.
I don't know if I had an amp to begin with. When I look at the back of my stock radio, on the right hand corner, there are four locations that were formed when the part was made. The bottom two locations clearly have pins and must have had cables plugged into it. The top left, well, rather than having pins, it has holes as if perhaps the cable that went there had male pins rather than a female socket. The final 4th position has neither pins nor holes. But molded in there is a part number and the word AMP. To be fair the entire mass plastic plug receptacle could have been made by AMP rather than the place to plug in an amp (if it had been made for one to begin with).
If its any help, there is a tag on the side of the radio with what looks like a part number: XL5F-18C815-AA.
What do you think, do I have an amp that needed to be bypassed, or did I pay extra for nothing?
Thanks in advance for your thoughts.
Mike
Hi Mike,
That number you listed should be this radio:
CLICK ME
If so, nope, they were right. If your radio was a complete "cube" shape, it would have had the on-board amp. If not, (like the one listed above) it has the external rear amp, which is why it's shaped that way. You can always pull the rear side trim and check, but there will be an amp back there for the radio on a rack all alone. :)
Cube shape radio with onboard amp:
CLICK ME
Thanks, I feel better about doing biz with them
Thanks. I feel better doing business with them. My radio does look like the one in the first link. Its sort to 2-din tall at the front, but within a couple inches going towards the back it immediately tapers down to only 1-din tall. Definitely not a cube.
I appreciate your time in digging up the pictures for me.
Mike
no prob Mike. :thumbsup:
So if I have this factory amp. that I don't know about yet. How can I bypass it when in stalling a new Deck,Amp., Sub., and door speakers?
If you're installing all of that, I would just upgrade the wiring and rewire to the doors and get rid of the factory wiring. If not, it's just a harness. Crutchfield will have them (or wherever you're getting your stuff) If you do use the harness remember that you have to turn on your remote factory amp by hooking the remote amp on wire to the blue amp wire in the factory harness or you won't get sound.
When you say just a Harness, what are you talking about? I am not sure what to look for on Crutchfield.com.
The wiring harness that will connect your factory plugs to the new deck. You will splice the wires of your new deck to the bare ends of the harness, then plug it into the factory plugs behind the dash.
When you go through the Crutchfield prompts about your vehicle, etc., it should give you the correct harness number. If not, you can call them and ask, they are quite helpful folks. :thumbsup:
I pulled the rear panel today, I don't have the Factory amp.. So the install should be fairly easy, just time consuming.
Righteous! ...much cleaner. :thumbsup:
Sorry to bump such an old thread, but I have the same questions as the OP. Can someone repost pictures of the different head units, as the links posted by Joe Dirt are no longer active.
