Does 2001 Explorer have an internal amp? | Ford Explorer Forums
Niteshade
Pittsburgh, PA
2001 Sport Trac
Does the 2001 Explorer head unit have an internal or external amp? It's not the premium system. It's just the base system.
I want to put the radio from the 2001 Explorer into a 1996 Explorer. Any suggestions?
Also, anyone have a layout of the wire harness connections for the 2001 explorer?
Thanks.
I believe that it has built in power if it is not the premium system.
If you are looking to replace the radio in the 2001 I would just get a harness that plugs into the factory plugs. I have a few pin outs for the factory plugs can you give a discription of the plug or plugs. If you can post a picture even better and I could fax you a diagram.
