My 04 just blew 1 and 4. I replaced the dail the knob goes into on the climate control and not the resistor. been working for a few years with no issues.
Thanks then I'll try changing the dial knob speed switch first and I'll go from there, How hard is it to replace the speed switch. Do I get to it behind the glove box?
With the manual system, after the radio bezel is off, remove the 4 screws holding the climate controls to the bezel then swap out the switch. It's pretty much self explanatory.
I got my oem switch from ebay. I haven't dealt with the resistor. If you do a search for blower resistor you should fine some threads on changing the resistor. There is a bunch of them.
Thanks! New here and just looking too pinpoint the problem. I had just called the dealer and he suspects that it may be the resistor but may end up aquiring both. Thanks for the link on the manual climate control....
Happened to me once. Same symptoms and for my part it turned out that my stock Blower Motor Resistor was at fault. Had to replace it with OEM since I couldn't find a nifty spare.
