Silversn95
- July 29, 2010
- Belle River, ON
- '06 XLT 4.0L 4X4
works now, great. Thank you!
If you have the auto climate control, you'll need the expensive resistor.
One of the pics on the first page shows that particular resistor. My '06 EB had the same issue. I thought..."no big deal" went in to carquest, asked for it...they rang me up, said the total...I damned near **** my pants...WTF'nH..LOL.
Worth it to have air at all speeds, but son of a *****, it ought to come with a bit of vaseline..
http://shop.advanceautoparts.com/p/...0-P?navigationPath=L1*14922|L2*15019|L3*15900
That I think is the blower motor resistor you need it's between 40 and 50 US dollars
Tools needed is a socket and a long extension or multiple short extensions.
To get to where it is at you need to remove everything out of the glove box.
Then press in on the sides so you can get the stops past the dash and the glove box should drop down out of your way.
Look strait back and you should see the connector for the resistor pull it off and get a socket wrench that will fit the two screws holding it in. Fairly easy job.
For reassembly do the reverse I will try and post pictures in the next post.
I did this tonight on my 2008 4WD and your photos were spot on, thank you so much. I bought the Motorcraft part for $51 delivered from Rock Auto.
Getting a light in the right place to see with my hand in the way was the biggest pain with the lack of room. It will be great to have the #1 and 2 setting again. Thanks again for taking the time for the explanation and photos.
yes the switch on the dash could be the issue. if you have a multimeter you could test the resistor as it is possible you got a bad one. you can also test the switch and blower motor with a multimeter to rule out a possible bad ground or loose connection.I just went through this process - 2010 EB 4.0. Blower only worked on speeds 3 & 4. Replaced the resistor and…. Still only works on speeds 3 & 4. What else could be the issue, the control switch on the dash?
