Critter92X
- November 28, 2005
- Lake of the Ozarks Mo.
- 92 xlt 4x4, 02' EB 4x4
(On my 02' E.B.)Sunday I stopped at the store and got out hit the lock on my remote and the horn sounded twice indicating a door was ajar,I went all around the truck shutting each door one by one and tried locking it and got the same 2 chirps of the horn even after I knew all doors were shut good.I went on in the store and came out and got in and started the truck,still had the door ajar message.After closing the drivers door several times it went out,made several more stops and same thing each time.The bolts to the latch are tight and I sprayed it with wd-40 but every stop I made that day it gave me problems.Got up monday and it worked fine and has since but I'm sure I will probably see this problem again.
I don't want to disconnect the wire.Where does the door ajar light get it's signal?From the latch?Any ideas?
