Replace springs.
Hi all, i have just replaced the springs on my front drivers side door handle.
First i removed the handle as per other posts.
I then removed the broken springs measured the wire guage and spring diameter and purchased a tension spring at bearing supply shop as they have a display rack with heaps of springs on display.
The one i purchased was 4" long for $2.00, enough to make 10 springs.
On arriving home i put one end of the spring in vice streched spring slightly and cut 2 springs at 4 revolutions.
Then using the removed broken springs as a guide i staightened the ends of the new springs and shaped them using needle nose pliers, they ended up at 3 revolutions the same as the broken springs.
Then i installed the new springs onto the handle twisting them on like you would when puting a key onto a key ring.
Took just over 1/2 hour to make springs and install on handle.
Reinstalled handle and works like new.
[ one of the old springs is twisted left hand and one righ hand ] i made them both from a right hand twisted spring with no problems and they worked fine.
Hope this is a help. Andy. Find Photo's at web address below (hope it works)
http://s1182.photobucket.com/albums/x451/anddoh/explorer%20door%20handle%20springs/
