davidmmm69
- September 1, 2003
- Location
- Fall river ma
- 2010 Ford Explorer V6 Fall River Ma...
- 2002 Mercury Mountaineer
well I finally got to some things replaced my dpfe and i took a couple of pics of the one i removed that has over 160000 on it....
After moving up to Mass and having to get cars inspected My 1995 barely passed and it was emission related so I was told.
Well since it is a 1995 and not OBD2 It isn;t easy to get the codes out of it with a test light...
So having not done anything much to the engine for over 2 years It is time now..
i changed the plugs which were toasted..I replaced the wires which the end going into the coil were totally crusted over wit0h corrosion..
I changed the Dpfe also the hoses going from that to the metal pipe. 1 was totally clogged from I guess carbon and the other was half way there...
wanted to replace the IAC but had the hardest trouble finding the replacement local after 4 differnt ones given to me they were all incorrect...
So I cleaned it today with electrical contact cleaner and also cleaned my MAF sensor which i could see crudded up..
Then came the moment to finally Seafoam after reading for hours posts on it.
I bought the can and poured it via funnell into the brake booster vacuum hose. after i removed the hose i thought the truck was going to stall but as soon as i started pouring it in it picked the idle back up.
I did get alot of smoke but not as much as i seen from a picture of i think it was ALDIVES truck..
mine was sall compared to that smoke screen.
it does run so much better..idles so smoothe.
I did get the part numbers from IAC and EGR so I can order them probably from Rockauto since they sell insids door handles and need one..
Next thing I will be doing is spindle lift and rear add a leafs and going to get I believe 35's when that is done.
I believe they will fit since I can not put 33's on with small rubbing at full turn..
and adding 3 inches of lift 35's no problem..
anyway love this site makes things so much easier to do.
as you can see I drilled out the rivets to open it up never seen a picture of the inside before.
and the picture does not how much at all as i would say i could have filled up a cap from a bottle of pepsi witht he amount of junk and carbon from the inside of it that fell out when i forced it open... No wonder these die after a while..
I would recommend anyone who never replaced it and had lots of miles spend the $35.00 and replace it took 20 minutes with that and the hoses..
