joachimf
- February 23, 2006
- Cologne, Germany
- '07 Eddie Bauer 4x4
Just to share a phenomenon. After changing out the rear brake pads of our ’02 Explorer back in 2008 there was a dragging rear right brake just a day later. I cleaned the pads and pushed back the caliper and everything went fine for some 10k mls. In Spring 2011 when I started to use the ’02 only occasionally the rear right brake started dragging, creating a lot of heat. Checked the pads and caliper and everything looked fine. Lubricated pads and sliders.
Last week when I test drove the ’02 after a three month break the rear right brake was dragging again. Because I expected this I was prepared. Took the car into my shop and examined the brake. The pads were not stock on the slider rails, the piston was stuck. So I exchanged the caliper Friday (I already had it in stock) with new brake pads & slider rails.
What concerns me a little is the reason this could happen. From time to time I change brake pads on different vehicles and I normally push back the caliper piston with a large C-clamp. This shouldn’t disturb the piston….
What do you think?
What do you think?
