kirakitty
- July 19, 2007
- Holbrook, New York
- 1996 Mazda B4000 (ranger)
I got this B4000 extended cab and it has always had a vibration. I changed the carrier bearing , which was shot. It helped, but not much. I took out the drive shaft and all three of the universal knuckles were out of phase, and the 2 rear universals were bad. I replaced aligned everything and replaced the center and rear universal. I was a drastic improvement but, Like an idiot I should have changed the front universal. It looked good, but looks are deceiving. I still had a vibration, so I changed it and noticed that the front yoke on the transfer case had some modifications done with a hammer. It is bent up and only half of the snap ring fits in the groove. I put the shaft back in( i needed the truck) and it was fine for about 20 miles then the vibration came back. I guess the damage is trashing the front universal. Is the front yoke the same on any other models, I would think the transfer case is the same on explorers and regular cab rangers. Am I correct and does anyone know were to get one??
