StuckInKentucky
- April 24, 2006
- Western Kentucky
- '99 XLT, 4.0 SOHC, 4WD
My '99 XLT (4WD 4.0 SOHC 5-spd auto) has a noise/vibration in the front end that we can't pin down any closer than it is somewhere between the tires and the transfer case. I always run it in 4-Auto . . . other than once every month or so I "exercise" 4-Lo in my gravel driveway (just to make sure everything is shifting OK).
As soon as I bought the Explorer in April, I had it serviced by a friend of mine and since it had over 110,000 mi. on it I had him change all fluids (front and rear diffs, transfer case, tranny, etc.) He commented that all the fluids he drained looked good and that he didn't see any evidence of undue wear - metal shavings etc. In addition, the truck received new lower ball-joints, a complete brake job (new rotors on front), and new shocks.
Life was good until about 6 weeks later when the passenger side front wheel bearing failed while I was on my way to work. This was replaced with a new one and I was on my way again.
Starting about a month later I thought I could feel something in the front end whenever I made a low speed left turn. It was really faint and, at first, I thought I was just overly paranoid (thinking back to the wheel bearing) but gradually it became more noticeable and really felt like something was rubbing . . . almost like the tire was rubbing while in the turn. Again, this was only when turning left. I had convinced myself that I had a bearing problem again (or bushings) when I noticed that if I let off the gas while turning, the vibration went away. The vibration could be felt through the steering wheel and the floor board.
Fast forward to the present, the vibration has become worse and is even audible at times. It is always when accelerating (even gradually) and nearly always when coming out of a turn to the left.
Finally I took it to the shop Friday and the owner took it for a drive. While I was in the passenger seat I could feel the vibration (faintly) in the passenger side floor board. When he switched into 4-Hi there was a very load moaning (whining, groaning?) sound from the drive train regardless of whether we were going straight or turning. He began to suspect the front differential and I asked him to check it out and see what we needed to do. When I checked back with him today, he was stumped. He said that the fluid levels were good in the diff's and transfer case and that he "fished" with a magnet and couldn't find any metal shavings other than a little bit on the rear diff drain plug magnet. He put the truck up on a lift and ran it in 4-Hi for a while but couldn't really hear anything other than with a stethoscope on the front diff and transfer case . . . but he couldn't pinpoint where the sound was coming from. After running it for a while he also checked for "hot spots" but couldn't find anything. In addition he checked the drive shafts and suspension parts and couldn't find anything loose.
Since differentials and transfer cases are pretty expensive to replace and then "hope" the problem is fixed I'm looking for help. Does anyone have any other trouble-shooting advice to help us track down the problem? Could the CV joints do something like this?
I've searched and found several other posts that described similiar problems but unfortunately I couldn't find one that reached a successful conclusion.
Thanks for reading and any help is appreciated.
Jim
Jim
