Driver power window motor remove/replacement pics??? | Ford Explorer Forums
pkelly04
Florida
1998 Explorer XLT 2WD
My driver power window motor looks to be dead. I pulled the door panel and unpluged the motor. I then ran power from the battery to the motor the motor just clicked once. I reversed the polarity and the same thing happened. It did the same thing a few months ago then miraculously started working again. I also pushed the switch with the motor unplugged and could here the relay under the dash working. So I don't think its anything but the motor.
Does anyone have any pics of removing the motor or instructions. I didn't see any dimples to drill out just a few access holes with bolts on the other side. I don't want to start removing stuff that isn't connected to the motor.
Thanks
BTW 1998 4dr 2WD SOHC
