Eric1971
- May 1, 2019
- 1995 Explorer Eddie Bauer
I found plenty of threads about driver-side windows but I could not find any that match my symptoms.
One-touch-down works just fine as do all the other controls on the driver's door. A few months ago it started that intermittently when I would go to put the driver window UP, it would go in short increments (maybe 2"), stop, then go, repeating this pattern at a steady rhythm with a matching click from (I think) a relay under the dash, and also with the interior lights blinking in time as well (when on). Sometimes the window would go up fine.
A few weeks ago it went from happening intermittently, to every time I put the driver window up so now I'm finally trying to track it down. I checked and replaced the power window relay, and checked the One-Touch Down relay and the Battery Saver relay. This morning I pulled the door panel off and checked all the plugs and connections and wires that I could get to. I think the motor is fine because when I unplugged it, the clicking/flashing remained the same except the window didn't move of course.
I just checked the exact order of events when I press and hold the UP button with the interior lights on:
Any ideas to check are greatly appreciated!
- the window moves up 1-2"
- window stops
- interior lights go off for a split second at the same time as the relay clicking noise.
- interior lights back on
- repeat
