sdhofste
- May 1, 2014
- 2004 Ford Explorer
My Aunt has a 2004 Explorer XLT and she had a run-in the other day that resulted in minor damage to the area around the drivers side door handle. The door was open and something caught it and pulled it "too far open" and bent some of the sheet metal by the door. I was able to get it very close to the same shape as it should be but I am having an issue with the lock/latch. Here is what I have found:
1. All Linkages in the door itself appear to be OK.
2. If the door is unlocked I can open and close at will from either the interior or exterior handle.
3. I can lock the door using the key, remote keyless or interior manual switch.
4. When pressing unlock on the key fob or number pad or sliding the manual latch I can see and hear it moving but...
The issue occurs that when the door is locked then unlocked, with the door closed the exterior handle does not open the door, it acts as it if is locked. The only way to open it is to use the interior handle which has a pushrod that has some unique method of unlocking the door.
Any help? I'm thinking I need to replace the latch but I would hate to waste $$$
