LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
This just started yesterday. I had the window down because it was hot and when I went to put it back up, it didn't do anything. I fiddled with the switch a bit and it did finally go up. Today, I forgot and put the window down again and the same thing happened. I did manage to get it to go up eventually but I will have to remember to not put it down until I get this fixed.
I believe that I had the motor replaced in this window already. I was taking someone to the airport during a snowstorm and put the window down to pay a toll. The window wouldn't go up again and I had to drive home in the snow with my window down. I would be surprised if the motor is going again already, so I guess it is likely the switch.
Is that what others here think as well?
Rockauto has several replacement switches,
DORMAN 901314 {#1L2Z14529BA}, Front Left; 5 Button ($76)
STANDARD MOTOR PRODUCTS DS1748, Front Left 5 Button ($92)
MOTORCRAFT SW7142 {#1L2Z14529BA}, Front Left 5 Button ($94)
Are there any preferences for parts here? I am generally inclined to pay the extra $18 and get the Motocraft part but I would get the Dorman if folks here have had a good experience and thing it would last a few years.
Leave it to Ford to take the part that will definitely wear out first and make it a 5-component switch that costs $100 to replace instead of 4 single switches that you could replace for $10 each. I have never had any switch wear out other than the drives side window. When this happen on my Caprice, I just took a switch from one of the rear doors and it worked just fine.
Thanks for the advice,
LMHmedchem
LMHmedchem
