Dying engine. | Ford Explorer Forums
Dying engine.
mmerlinn
Here, There, and Everywhere
Aero 93@430000: 90@155000
New problem. 93 Aero 3.0L.
Engine dies every time I slow down.
But it ONLY happens once I have exceeded 10mph. Keep the speed under 10mph and it never dies.
Engine runs fine as long as I keep the revs up, like freeway speeds or city streets without stoplights or stop signs.
Every stop sign, every stoplight, requires a restart UNLESS I keep the revs up.
Any ideas what would cause the engine to shut down?
FWIW this does not appear to be a fuel issue. Delivered quantities of fuel and fuel pressures are within specs at all speeds.
Swapping control modules changes nothing.
Solved, but I have no clue what was causing the Aero to die.
Yesterday, I "drove" the Aero to a local wrecking yard, where I borrowed a spare control module that they had which gave me 3 modules to play with.
Plugged in the borrowed module. Drove around. Problem gone.
Plugged in a different spare module. Drove around. Problem gone.
Plugged in the ORIGINAL module. Drove around. Problem gone.
Cycled them REPEATEDLY for the next 2 hours. Problem stayed gone.
Finally, plugged the original back in and today am driving the Aero with NO dying issues.
All I can think of is either a bad connection or a wiring harness issue near the module since that is the only thing I monkeyed with. If the problem returns, I will closely examine the harness for problems.
