easiest way to change transmission filter on a 98? | Ford Explorer Forums
mavieman73
Inwood WV
98 explorer xlt
Got all the fluid changed but cant seem to get the pan off....never done this on a 98 before any help?
on my 98 i have to remove the front driveshaft to get the transmission pan off
ok after i take the bolts out of the driveshaft on the front rear does it just pull out of the tc?
and i have it on ramps so after i pull the driveshaft out wont it try and drift back? i mean i have the tires chucked
What's the problem? Nothing under the transmission in my V8 AWD, but there may be something in the way for yours. To get a meaningful response, please provide the engine type, and if it's a V6, also whether 2WD or 4WD.
Incidentally, you seem to be doing things in the reverse order. Why would you remove the pan after changing all the fluid? You will lose about 5qt of your brand new fluid by doing so.
just dropped one end gave me enough room and as long as your jacked up and wheel chocked safely you will be good
This is really confusing. Are you working on the transmission or on the transfer case?
on my 98 sohc sport the cats and front driveshaft makes it impossible to drop the tranny pan u get movement but not enough clearance to get to the filter
