civic_rider
- April 20, 2005
- Coquitlam, BC, Canada
- '92 Civic Si
Hey guys,
Ok, I'm new to THIS forum (actually ventured into a domestic forum!) but I'm quite familiar with online forums, I'm a Mod at a online Civic's Club. Yes thats right.... No slamming me for supporting the imports, I have a perfectly legit reason for being here - I'm going to need your help.
See, two of my friends own early-90 Explorer's, and them having little mechanical knowledge, I get the request to work on thier trucks.. so this will be my first foray into the domestic side of life.... Hopefully I am still welcome here
My first question: Have a CEL on the '93 Explorer (OBD1), now, on Honda's, you can add a jumper to a plug under the dashboard and the CEL will flash out a code, you look up the code, and you have whats causing the CEL. Are Ford's the same??
I've looked all over the net and cannot find a list of CEL codes for Fords.... are all OBD1 codes the same? (between Honda/Dodge/Ford/etc) And also, can you pull the ECM code from a Ford without buying a 'code scanner' ??
Thanks for all your help. Hopefully this is in the right forum.
cheers
~mike
cheers
~mike
