xdviper
- February 15, 2007
- 1997 XLT
Yesterday, I went ahead and cleaned out the IAC w/ electrical cleaner, cleaned up the throttle body (lots of carbon buildup), and didn't bother with the MAF (will do after replacing EGR Tube) and replaced the EGR valve, the valve wouldn't come off, so while trying to take it off, I ripped off the tube that connects to the manifold off, I ordered an new one, should be here tomorrow. I reconnected the broken tube somehow and new EGR and cleared off all codes.
Now my problem is, I'm still getting the P0402, which I'm guessing is because the tube is ####ed up and needs to be replaced, and or while playing around when the engine was hot, I removed the reinserted the vacuum line that connects to the EGR. While off the engine idle improves, it's much steady and doesn't hesitate. While plugged in, it blogs down and hesitation occurs.
Before I went ahead and changed everything I still had codes p0171, and p0174 and they're still coming on, I'm guessing O2 sensors or EGR acting up?
Now I'm totally lost until tomorrow when I get the tube replaced, but until then anyone have any ideas????
I will clean out the MAF sensor tomorrow with my mechanic that'll replace the tube for me, so I'm hoping that gets rid of the p0171.
Oh and for the vacum hose that connects to the EGR, when I put my finger over the hose, I can feel air, either sucking or pushing, I can't tell.
Thank you guys, and have an Happy Thanksgiving.
I've also included an video, just for the sake of diagnosing the problem.
