Electric fan or Pully debate | Ford Explorer Forums
rookieshooter
Moderator Emeritus
Elite In Memoriam
Martinsburg WV
84 BII "Li'l Samson"
There been a lot of talk lately on elec. vs. belt drive. With that said there is a good article in this months Off-Road Adventures On electric fans. I have not decided on a type of fan yet on my B11 project, but after listining to u guys and reading this I think I'm going electric. See Manufacturer Profile.
Well, I can certainly attest to eletric fan's performance. I ran a Black Magic fan in my 2000 Ford Ranger 3.0 and it made the ranger come alive. I haven't yet put on in the X, but due to the larger size of the fan on my 5.0 X, I can only see good performance coming from that type of swap.
The only thing you have to make absolutely sure of is that you get a fan that pulls enough air to keep the radiator cool. Again, I personally recommend the Black Magic series of fans, huge sucking power for all the power your X can muster.
In addition, if you do a lot of towing, you can look into adding an Aux. Tranny cooler with an electric fan, nice and cool, hehe.
I'm going to check out their dual fan Monster series for full size trucks to see if it will fit on my radiator. Or the knew single X-treme fan. I like the idea of dyno proven HP gain of up to 17 and torque by 20 pound -feet and the adjustable t-stat so it will come on at cooler temps when you first start on a crawling along trail ride. Not to mention you can shut down the fan in deep water.
That looks like a very hefty setup. The reason I suggest the Black Magic series is they tend to pull way more CFM than any other setup.
One suggestion I will make if you are planning on using this for off-roading though. On the fan I received way back when in my Ranger, the power and signal line hookups all used blade style connectors. The problem I ran into was that during heavy off-roading, the tabs would actually fracture from the forces put on it by the wiring. I ended up having to re-solder all my connectors in place. This is not necessary though if you fill the connector area with a clear silicone. The silicon will insulate it from shock and keep it from moving, but still allow you to later remove the silicone and pull the connections if you need.
Those are two big concerns with an electric fan for an offroad truck...
vs a clutch fan
