Electric Window issue | Ford Explorer Forums
woodlands1
Macomb IL
2005 Sport Trac
Hello everyone! About 2 weeks ago my windows just stopped rolling up or down. I have power windows on all 4 doors, power moon roof and power rear window. The power moon roof and power rear window still work fine but none of the door windows will roll up or down. Every now and then if you mess with the button enough on the driver side door there still be a loud buzzing noise. Also if you try the buttons on all the doors nothing happens at all. I kind of figured if it was a motor issue in the drivers door that atleast the other windows would roll down using the buttons on their doors, but no dice nothing happens. I checked the fuses and they are all good. Anybody got any ideas?
You have mail.
I'm having this same issue. Ncranchero (or anyone else), can you help me as well, please?
I'm having the same issue, however mine is only with the front passenger window once it's really cold out. When it's warm, there isn't a problem (or doesn't seem to be). It goes down EXTREMELY slowly, but tends to go up just fine.
Suggestions?
Fixed! After researching this site some more, I pulled back the door jam boot and found a broken wire. A blue w/black stripe wire, reconnected it and all is good now.
