Electrical Issue poss relay | Ford Explorer Forums
blckdrgn1987
Fort Stewart, GA
98 XLT 4.0 SOHC
Greetings
I have a 98 X with a lighting issue. With out the long story you have to remove the fuse from the #26 slot on the fuse block or else the lights stay on all the time. So you leave the fuse out start the truck and put the fuse in and everything lights up then pull the fuse the lights stay on till you turn the truck off and pull the key. I am hoping that it is a relay that is shorted out in the closed position. I am not sure where that relay if it exists might be. Any help or suggestions would be welcome.
Geoff
:us:
