Kamaaina
- January 12, 2003
- Hawaii
- '96 XLT 2wd
Hello everyone. I have a weird problem that I hope somebody out there can help me solve. First off my Explorer is a 1996 XLT with the 4.0 OHV engine, bone stock & 78K miles. When I first get into the truck and I turn the key to ON there's a relay clicking on & off under the dash that lasts for about 5 seconds, then stops. After I start the truck it clicks on & off again for another 5 seconds then stops. After that it runs normal with no faults. After the truck is warmed up and I make several separate trips during the day it doesn't do it again until I park it overnight. I did notice that when the relay is clicking the interior lights flash on & off in time with the relay. Another problem is the driver's power window. It will go down normally but will stop & go going up, I can hear a relay clicking on & off under the dash as this is happening (don't know if it's the same relay as the first problem). If I hold the window switch in the UP position it will stop & go and then quit all together. After about 30 seconds I hear a click under the dash and the window works again. Is there some kind of circuit breaker that controls the window? It sure acts like a breaker is tripping and then resetting. I checked the electrical manual but couldn't find any breakers anywhere. I don't think it's the relay as if it was defective it wouldn't be clicking, something is causing it to go on & off. Just wondering if my two problems are related. I could sure use some help in solving this problem before something gets fried. Any help would be appreciated. Thanks all!
