Electrical problems | Ford Explorer Forums
Electrical problems
LimitedV8
Port Coquitlam B.C Canada
1997 Limited
Hey guys
1-Front headlights highbeams work,driving lights work but my low beams don't.First passenger side low beam packed it in so i replaced the bulb still didn't work then drivers side packed it in changed bulb now both don't work.My day time runing lights come on and like i said same as high beams.
2-Fog light's worked before now they don't work either(maybe affileated with the headlights)?
3-Brake light's not working the only one that works is the center one on top of hatch.l also replaced the bulbs no luck.My truck would also lock all door's automatically when i put the truck in drive and that stopped working when my brake lights packed her in?Any ideas on any of them would be greatly appreciated.Thank's Duncan
have you checked the fuses ?
-=bmacd=-
checked every fuse and relay on truck all's good
For the headlight problem, your headlight switch might be bad....
that multi-function switch is a *****.
-=bmacd=-
