nostarttireflat
- March 10, 2004
- Phx, AZ
- 91 ExploDer
emissions report as follows:
Test.... Emission... Standard... Result..
Hydrocarbons (HC) 5.52 2.00 F
Carbon Monoxide (CO) 221.22 20.00 F
Oxides of Nitrogen (NOX) 0.76 4.00 P
Changed plugs and wires, O2 sensor, oil
The guys at work tried to put on the Genisys thing and got code 21 (they said engine was to cold for test) but since then notice temp gauge not working since its right above the Check Engine Light, on Monday the CEL didn't come on and temp gauge worked. Friend said temp sensor was bad so went to Autozone and they asked if the gauge worked, told them what happened and they said it was temp switch worked fine Monday night, Tuesday NO GOOD but gauge doing more than before. Sucks up the gas and smells, also oil cap smells like gas. Any ideas of where to start and rule from major problem since $ is short (single dad w/daughter)
Thanx in advance for any & all help TJ
