Empty Gas Gauge and wiring | Ford Explorer Forums
welsh
2002 Explorer
I've received some very helpful information as to why I get a a constant "empty" read on my gas gauge. Both sender and cluster have been replaced. I'm following the wiring from the dash to along interior chassis compartment and then to the tank. The wire is yellow / white. This wire makes a connection to the transfer module under the dash. I'm confused by this. Question: where can I find a detailed wire diagram of the the sender unit . Thanks
Maybe this link will get you what you need -- it helps people to help you if you display engine size, model, etc --
Dead Link Removed
