Engine bay rattle | Ford Explorer Forums
Engine bay rattle
thebrakeman
Canton, Michigan
2006 Mercury Mountaineer
When driving, I'm getting a rattle at around 3500-4000 rpm.
It's most notable in the lower gears, but I'm assuming it's there at higher speeds, too.
It sounds exhaust-related, either a heat-shield, exhaust manifold, etc, but I can't isolate it, since I can't get the noise when parked. Putting in gear and holding the brake does not get the noise either (nor do I like getting it up to 4000 rpm in drive while holding the brakes!).
Anyone ever get this? Pointers on where to look, where to poke?
To find a broken heat shield weld, I've used a large screwdriver handle to tap on the exhaust.
Recently heard that the 4th gen V-8 have a problem with right side maniflod cracks? Hope this doesn't apply to you. (or me)
probably needs a muffler or cat. something broke apart.
