The definition you have for p1121 is also misleading. p1121 is set if the correlation between the TPS and the MAF do not agree.
This can be do to an open or shorted circuit i.e. a broken wire (rodent damage), crusty green corroded connections or chaffing.
It can also, and this is most likely, a bad MAF. Easy way to test this is to unplug the MAF then clear the code. (the PCM turns of the injectors in this situation to prevent uncommanded wide open throttle) Then the engine will start on the default fuel strategy. It will run rich as hell and badly but it will run. However if you do have a shorted wire anywhere on the 5 volt reference you may not learn anything from this test. A good visual inspection of the wiring may be time well spent.
This condition in my experience is the MAF shorted to ground internally. Or the resistor element is actually broken, which you can easily see visually.
