Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
- Forums
- Generation Specific Forums
- 2020 - 2026 Explorer - Lincoln Aviator
- Stock 2020 - 2026 Ford Explorer & Lincoln Aviator
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
engine for the 2020 explorer Platinum
- Thread starter kenz
- Start date
Add an avatar, upload photo attachments, and more!.
- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
blwnsmoke is correct. If you do a Build and Price on the vehicles you will see that the ST gets a 3.0L 400 HP engine while the Platinum gets the 3.0L 365 HP engine.Does the 2020 explorer platinum get the same engine as the 2020 st model? Order guide seems to indicate this.
Carleton Wu
- February 8, 2019
- Broadview Heights
- 2015 BMW X1
Isn't platinum the most expensive trim? Why wouldn't they do the 400HP EcoBoost?
- December 28, 2010
- Callsign
Yes it is but the Sport is a 'Sport'! Why would the Platinum need a 400 HP engine?Isn't platinum the most expensive trim? Why wouldn't they do the 400HP EcoBoost?
- February 25, 2011
- Moderator
- 2020 Explorer ST
Platinum is the highest trim but is known for a more luxurious ride.
The ST is the Sport model which is known for performance. It is designed to handle better, corner better, stop better and well.. go faster.
The only thing the Platinum has over the ST is a more plush interior.
Ima DingBat
- January 26, 2019
- Location
- USA
- ChocolateTown - USA
- 2020 Explorer Platinum
Does anyone know if the 2020 Platinum engine can be "re-tuned" to regain some or all of the performance differential with the 2020 ST?
RhinoQuartz
- December 16, 2018
- 17 Explorer Base
Considering production hasn't even started at CAP, the only way to know that is if you knew one of the engineers who worked on it.
- December 28, 2010
- Callsign
I don't know for sure but I wouldn't think so. Even if it was possible, you'd have a brand new engine with no warranty on it. Not sure if that is worth a gain of 35 HP.Does anyone know if the 2020 Platinum engine can be "re-tuned" to regain some or all of the performance differential with the 2020 ST?
RhinoQuartz
- December 16, 2018
- 17 Explorer Base
If the difference between the engines is the tuning, like how the limited and platinum trims are on the 4th gen expedition, I would think it definitely could and would be done in short order.
Now, whether or not its worth doing to a brand new engine is a different matter altogether. Especially considering how horsepower only means so much without the requisite amount of torque to put it on the road.
As Bob Lutz once said, "Americans buy horsepower, but drive torque"
Ima DingBat
- January 26, 2019
- Location
- USA
Thanks for the replies. I agree that if "re-tuning" would void my warranty, then it's out of the question. Thanks again.
- February 25, 2011
- Moderator
- 2020 Explorer ST
You can not retune an engine by Ford or a dealer that doesn't belong. When you hook the vehicle up and it reads the VIN, it only allows programming for whatever the original configuration was.
That isn't to say you cant go aftermarket with tuning but then risk your warranty.
- February 25, 2011
- Moderator
- 2020 Explorer ST
If you want more plush and upscale, go platinum.. if you want Sport and handling, go ST. You will not have both.
Flying68
- September 7, 2011
- Wichita, KS
- Ex Ownr 12 Explr Lmtd AWD
Or get an Aviator if you do want both.If you want more plush and upscale, go platinum.. if you want Sport and handling, go ST. You will not have both.
RhinoQuartz
- December 16, 2018
- 17 Explorer Base
Right, sorry. I should've clarified I was speaking only of aftermarket. The Expedition comparison was simply to show how trims differ by engine tuning only.
- February 25, 2011
- Moderator
- 2020 Explorer ST
I plan on tuning mine as soon as I get it. But I also am aware of the potential warranty denial if the engine goes boom.
Napalm
- June 18, 2015
- Memphis tn
If they do like past history - the engine is actually the same - but the exhaust and intake tracks might not be.
Especially the exhaust. so that the platinum is that touch quieter. No growl, no turbo noise, no blips. And yes a different engine map.
Hence the 35HP difference. but mechanically the exact same engine.
metroplex
- October 29, 2000
- Location
- Detroit, MI
- Detroit, MI
- 2018 Ford Explorer XLT
I'm with you. Fusion Sport gets 2.7 EcoBoost, Fusion Platinum gets 2.0 EcoBoost. Makes no sense at all. Throw the high output engine into the highest luxury trim as well. Otherwise, why not offer the biggest engine in the cheapest trim as well? Just like the old days. I don't really want to pay for any of the luxury/electronics junk.
- December 28, 2010
- Callsign
I think some are missing the point and why the Sport is called the 'Sport'. Hence the more powerful engine to go along with the special tuning of the suspension and other features not available on the other trims.
- February 25, 2011
- Moderator
- 2020 Explorer ST
Exactly what Peter said. They Sport gets the highest output and better handling features (cornering, acceleration, braking, 0-60, 0-100 etc). The Plstinum is more a gussied up Limited (more luxury, smoother ride) etc. You dont get both and it makes sense to me.
Similar threads
- Replies
- 9
- Views
- 4,665
- Replies
- 49
- Views
- 10,424
- Replies
- 11
- Views
- 2,877
- Replies
- 2
- Views
- 824
