summs
- March 16, 2021
- Boulder, Colorado
- 2002 Explorer Limited V8
I am in need of replacing my engine mounts, one side is completely shot. I’m surprised to see that there is almost no info on here about the procedure. I’ve found instructions that are much better than in the Haynes manual but I still am trying to figure out the best places to jack the engine up to remove the mounts. I know it doesn’t need to be jacked up really per say but more just to take the weight off the mounts. If any of you have any suggestions. I’m looking for a good spot to lift the right side and left side and then also the transmission. If I’m going to change one then I’m going to do all 3. Thanks for your help.
