Engine Knock | Ford Explorer Forums
Engine Knock
808hawn
Honolulu, Hawaii
2004 Eddie Bauer 4X4
Aloha,
2004 EB 4.0.
Car was running fine on Friday. Rained all weekend. When I started it on Monday there was this engine knock. Knocks with the serpentine belt removed. Put in seafoam and ran it for a while, no change. Drove it a few minutes ago. No codes. Runs fine except for the knocking.
Any ideas or comments will be appreciated.
Thank you in advance!
https://youtu.be/E9ZEMM13z3o
Video is set to private.
Two things that can "knock"
  • Broken chain guides.
  • Torque converter
Thank you Number 4. Video is public now.
If it's a spun bearing (which causes the connecting rod to slap the crank on the up and down stroke) you'll have glitter in your oil from the bearing disintegrating.
