Engine lost the power | Ford Explorer Forums
MartinCZ
Czech Republic
1998, Ford Explorer
Hello,
i have F.Explorer 1998, 4.0 SOHC, the cas was 6 year without battery. Now i want use it again, but engine not working normally. I was chanded both oxygen sensors, Engine Intake Manifold Gasket , fuel pump, fuel filter and nothing changed. Engiene sometime start normaly and afrer few second go down withou power.
Here is my video. Do you have any same trouble ? Thank to tip and help.
Check your Catalytic converter and muffler
For clogs
Also check your fuel filter it may be clogged
I did not see the check engine light turn on with key, but, another one did when you rekeyed the ignition.
Scan for trouble codes please.
OK, i will send it next week...
Six year old gas in it?
It’s gonna run like absolute ass on that.
Check fuel pressure first, then…
Siphon all the old gas out, fill it up with fresh fuel, throw in some heet or dry gas for good measure
Check intake tract for rodents and nests
Hi,
on weekend i havd time to try repair my Ex. I chanded the iginition coil and ignition cabler. But start was the same that before change, but I have from my testing one point. When engine run, have no problem about 900 engine speed, and after one time somethin come and engine is working normaly. No problem go from 900 to 4000 engine speed . I try to drive with car in my garden, but car drive only when is on straig path, but whem come little hill he lost power, engine stop and it is big problem to start engine again.
Do you mean that will be the gas pump ? or other stupid thing ?
And when i try read the faul code, there i nothing. All als healthy car :)
Try cleaning / spraying out your throttle body with some spray cleaner..... and check all your connections of air intake..... and check air filter for rodent nest as C420sailor mentioned.
