Engine oil cooler lines... HELP! 1998 EB 5.0 | Ford Explorer Forums
Jeff213
Stockton, California
98 mounty 5.0 4x4
Callsign
KM6BVN
I have been searching like crazy for engine oil cooler lines, mine are leaking bad. Ford no longer makes them, none of the auto repair shops carry them. What have you guys used for replacement engine oil cooler lines? Do you have a source?
The engine oil cooler is mounted to the block and uses no oil lines.
There are lines for the power steering cooler, and also lines for the transmission oil to radiator cooler, then from radiator to auxiliary trans ccoler and back to trans.
