schoop
- March 28, 2016
- michigan
- 2002 explorer limited
Spent 5 days online looking for an answer or help. Wife has 2002 explorer limited with 4.0 auto 4x4. Pulled out of drive and once in OD she lost OD then selected 3, still nothing. I went to her on side of rode and realized there was no rev either. Selected 1 and it moved with good solid gear then shifted 2 and that was good but no other gears. I pressed OD button to turn off and the light flickered quickly and constant, not what i would call a flash, definately flickering. I scanned it once back to house and it had 2 codes, first one said it was running rich 2nd one was P1700. Removed pan which had no debris at all in it and changed filter but first checked solenoids and all ohmed within spec. Filled back up according to the book and erased codes. Same problem. Whether in drive, 3rd or reverse, vehicle would move slightly when throttled but wouldnt drive unless 1 or 2 were manually selected. I kept messing between ranges and all of the sudden reverse worked good! Put in D and it worked too! Took for a ride and all was suddenly good until i kicked it down. It then sputtered like i hit rev limiter until i stopped vehicle and then it all worked again!!! Took off thiz morning and it sputtered again when it shifted 3rd. I stopped on side of road and accelerated easily and it took me to work, 15 miles with no more issue. Left work and the whole thing started all over like this morning!! Can anyone please help us! I am ver mechanical but very stumped by this! I do suspect the cat to be clogged as its been smelly lately, but im also wondering could it be somethinv like the TPS?? No codes have came back yet either! HELP....please
