arco777
- April 6, 2008
- 1994 Explorer 2dr 4x4
As I'm driving down the road in Overdrive, with steady throttle the engine surges. RPMs rise and fall, see video below.
Video here - http://youtu.be/H4wuoj0nmQA
Video taken at about 70 MPH, cruising with steady throttle on level ground. This occurs at any cruising speed in Overdrive, though the amount of surge varies slightly with the speed.
No KOEO codes, no KOER codes, cylinder balance test results 90.
Swapped PCM, new MAF, and TPS with no change. New spark plugs and wires. Torque converter seems to properly unlock when I tap the brakes at speed, then locks up again as it should.
Any ideas why this is happening? Thanks in advance!
