Chickensandwich
- April 24, 2021
- Madison
- 2018 Police Utility
2018 eco boost PIU, 83k. I’m getting surging issues. Before it’s mentioned, I looked at the other posts.. so my issue seems to be just a bit different.
It surges, high speed and definitely low speed. There are no engine codes popping up, it doesn’t go in to limp mode, it doesn’t stall. It seems to affect the transmission. I would guess it surges right at the shift point and causes the transmission to hunt a lot and causes issues. I read about a throttle body issue, it makes sense, but I thought they fixed it. Is this still an issue?? I don’t have a tune on it, and use regular gas.
The explorer recently had brand new motorcraft plugs put in, a new fuel injector, all turbo tubes replaced, and the engine was carbon foamed out by the dealer. These were done in the past and not due to this issue, but i thought it may be relevant.
Is this still most likely a throttle body issue?
