Engine swap | Ford Explorer Forums
Engine swap
Trapper J
02 explorer
I'm wondering what different engines will fit in my 02 explorer. My current one, a 4.6l, seized up I'm wondering what my choices are.
Mostly I was wondering if about any 4.6 would fit. I can get a 4.6 from a 98 crown Vic police pretty cheap, but not sure if it will go in.
Do not go that old! I repeat do not go that old! you will have to replace a lot of the sensors the crank gears, fuel rail, injectors, trigger wheel, different motor mounts, Also the explorer uses the aluminum PI heads, the older Vic will not. The Explorer 4.6 is also an aluminium block, where as the one in the Vic I believe in cast iron. You will have to tear both engines apart and swap parts back and forth. The easier thing to do would be to swap in another used explorer 4.6. Much less time consuming and exceedingly less frustrating!
