mace
- March 10, 2005
- Mullica Hill, NJ
- 2000 Mountaineer AWD 5.0
Installed oil filter relocation kit, and didnt notice at first, as I have a jumpy tach...but the RPM's are lower. Engine noticebly running cooler per the temp gage also / maybe 20 deg cooler. In Idle, when hot, down 100rpm, and pretty much down 100-200rpm through most speeds. Not sure if this is a good or bad thing. Real oil press gauge in normal ranges, avg 50 psi.., OEM oil switch gage in the middle, engine sounds good, no engine lights on. Is the engine just running easier, or is is struggling? used 5w30 Mobil syn, truck has 78k. Air temp 50..
Very concerned; should I be worried?
