Flash
- July 5, 2004
- Brisbane Australia
- 1997 Limited
it's not really a sealed system. if you don't want to worry about moisture, you can switch to silicon brake fluid (i use it in my classic cars) but you have to replace pretty much the entire brake system as DOT 3 and silicon fluids don't play well together.
When water gets into the system it will mix with the DOT3 and reduce its boiling point a bit. If a lot of water gets in the boiling point will reduce a lot.
This will make steam which is a compressible gas until the brake fluid which isn't.
The trouble with using silicon is that water won't mix in leaving the water to sink to the bottom of the system, the calipers, where it will boil at a paltry 100 degrees C, make a compressible gas and you'll have no brakes.
I prefer to just change the DOT3 regularly.
