stevechaos
- March 11, 2013
- Dallas, TX
- 2001 Explorer
Ok, so thanks to using this place like a repair manual for the past couple of weeks I have been able to correct the dreaded timing chain guide death rattle.
I bought the 2001 2wd for a good price because it had the clatter, and I got the complete kit just in case. I tore it down and found only the main chain guide was shot. And by shot I mean completely gone. The frame was still there (somewhat) but the majority was broken and worn away. I don't see how the truck even drove with the massive amount of slack in the chain! Not only did it drive, it drove rather well. It was just loud.
Anyways, so I replaced the chain tensioner/guide on the main chain and found the one on the camshaft to be in good shape somehow (changed recently?) so I left it be and buttoned everything back down. I also pulled the oil pan and fished the broken pieces as well as the ground up metal pieces from the tensioner frame out, reinstalled and topped off all the fluids and such.
So then the moment of truth: I started the truck. It cranked right over and ran nice and quiet...for a few moments. Then the idle got slightly erratic for a bit and then smoothed out. It spit out some white smoke for a few seconds, but not for very long. I turned it off and cycled it on and off a few time and it always starts back up and runs ok, the only noticable issue being that the CEL is on and the erratic idle that seems to go away after a bit.
I'm not even sure where to begin looking. I figured it could be a vacuum leak, so that's my first course of attack, but then I have no idea. Could it have jumped time a bit since the chain was so sloppy? Seems unlikely, but nothing is impossible.
Any idea fellas? This is my first bout with one of these 4.0's, so I await your expertise.
Truck is a 2001 4.0 2wd.
Thanks in advance.
Thanks in advance.
